August 30, 2019 at 6:25 pm
adholpure
SubscriberI am working on the project of Modelling of Combustion Process of Internal Combustion Diesel Engine Using Ansys ICE Fluent,
As the image below show is from the IC engine combustion tutorial pfd file. But when I reach in ANSYS Fluent after doing all the steps mentioned in the tutorial, I am trying to set the output parameter in the parameter dialog box and I am not getting the same dropdown box as mention in this pdf, attached the Image below.
Instead of this drop-down list, I am getting only one option (from report definition)
please help to Identify this problem and finding a solution.
September 2, 2019 at 10:59 am
Ansys EmployeeDuplicate
2656
2120
1347
1118
461
