July 31, 2019 at 8:39 am
adholpure
SubscriberI am working on the project of Modelling of Combustion Process of Internal Combustion Diesel Engine Using Ansys ICE Fluent, in Which I am facing problem to obtain the Desired Result.
My Objective: To plot Graph between Crank angle and Cylinder Pressure of IC Engine
Problem: The output Report which is given by the Ansys ICE Fluent after simulation does not have the correct plot.
I want to obtain the Pressure vs Crank angle plot (figure2) but the obtain report contains flow time v/s time steps plot(figure1) in place of Pressure v/s Crank angle and still, after a number of simulation and data modification the obtain report does not have the desired plot.
July 31, 2019 at 10:13 am
Ansys EmployeeI don't use the IC tools, but check what you're monitoring in the reports.
August 1, 2019 at 6:18 am
adholpure
SubscriberI am trying to obtain the Plot between Pressure inside the IC Engine Cylinder and Its Crank Angle.
I am using the Combustion simulation part of the ICE fluent.
But I unable to identify the problem or Mistake in my simulation setup which creates the wrong plot.
I also take the reference from here https://www.sharcnet.ca/Software/Ansys/17.2/en-us/help/wb_icom/wb_icom.html
August 1, 2019 at 10:36 am
Ansys EmployeeCan you screen grab the report set-up?
August 1, 2019 at 2:42 pm
August 2, 2019 at 10:46 am
Ansys EmployeeIs there a panel where you set up the graph?
August 5, 2019 at 1:55 pm
adholpure
SubscriberTo obtain the output plot we have to define the various monitors definition in ICE fluent. But most of the time the Monitors definition setting is already defined. I am also using the Default Monitors Definition Setting.
I have also done some manipulations in this Monitor Definition, But still, the result is not satisfactory.
August 5, 2019 at 3:27 pm
Ansys EmployeeAnd if you can put up one of the reports (use edit) so I can see that?
August 5, 2019 at 7:36 pm
adholpure
SubscriberI am attaching one of the reports which are automatically generated by the Ansys after completing the simulation.
As the simulation setup is showing up to 1000 number of time step but I run it only for 20 to 10 number of step, just to check whether I am getting the write result. But as I mention above the plots are not correct
August 6, 2019 at 12:42 pm
Ansys EmployeeI can't see anything, and please remember I also can't open attachments.
August 6, 2019 at 4:00 pm
adholpure
SubscriberSir, Sorry for the inconvenience, I am attaching the google drive link of the Ansys report which I mentioned above.
link :https://drive.google.com/drive/u/2/folders/1yMs7VBFKstZfpZfdYlmriDwTmHZHH9FV
August 7, 2019 at 2:31 pm
Ansys EmployeeI still can't open attachments.
August 7, 2019 at 3:06 pm
adholpure
SubscriberSir,
Can you please give your email id, so that I can share this file.
August 8, 2019 at 9:54 am
Ansys EmployeeNo, you must put all images on here.
August 8, 2019 at 10:54 am
August 8, 2019 at 11:53 am
Ansys EmployeeCheck how you've defined Chart 6: how does it differ from the others? And I need the INPUT settings for the various charts, otherwise I'm guessing what you set.
August 8, 2019 at 4:58 pm
adholpure
Subscriberfor explaining one by one,
I have found some videos on youtube Which is same as my project work. I also follow the same steps as mentioned in these videos.
These videos are of very short duration.
part 1:
part 2:
part3:
part4:
part5:
part6:
August 9, 2019 at 9:32 am
Ansys EmployeeOpen up the panel where you define the monitors and show me what the settings are. As some of the graphs seem to plot crank angle v something it's odd that others don't. Check each monitor carefully and post the set-up panel.
August 9, 2019 at 7:34 pm
adholpure
SubscriberEven after doing everything the same every step same which is shown in the above-mentioned videos, the resulting plots are a straight line(which is wrong). But in the videos they got the right plot, I cant understand how
I do everything the same, but my results differ, How ?????
August 9, 2019 at 7:36 pm
adholpure
SubscriberI think some steps are missing in the videos or some data which is useful for obtaining the right result.
August 12, 2019 at 11:57 am
Ansys EmployeePossibly, but as some of your results make sense, and some plot crank v time I'd go through and check your settings.
August 12, 2019 at 5:15 pm
adholpure
SubscriberSo, Sir, What can I do
if you need some more information from my side, I will ready to provide you
August 13, 2019 at 9:24 am
Ansys EmployeeLook in the settings for one of the graphs that's not working: ie how did you define the axis?
August 24, 2019 at 5:21 am
adholpure
Subscriberhello sir,
sorry for the late reply
After too much searching, I identified my problem
I need these files (tut_comb_sect.x_t, injection-profile, Diesel_1comp_35sp_chem.inp,
and Diesel_1comp_35sp_therm.dat) to run my set up.
Sir, please send these files.
I am very grateful to you.
August 28, 2019 at 12:28 pm
Ansys EmployeeThese will be included in either the tutorials that come with the software or on the Training Hub. You should have the former, and the latter can be downloaded with a subscription: I don't have copies (and can't share files either).
August 28, 2019 at 7:29 pm
adholpure
Subscriberok thanks sir
2508
2064
1279
1088
456
