LS Dyna
LS Dyna
Failed linking of two systems in the project schematic
    • Ben_Ben
      In the first solution I've found that the .cdb file is missing. I tried rebuilding the model from scratch but got the same error
      Could this be part of the problem? If so how can I produce that file.
    • Ben_Ben
      I am wondering if these warnings are causing the error.
    • Ben_Ben
      I have solved my problem. The inclusion of Mass Scaling was preventing the transfer of the solution in the project schematic. I turned off Mass Scaling, reran and the solution transfer now works.
