Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Failed to copy local file error on Maxwell 3D
    • Bati Eren Ergun
      When I run the 'Generate Mesh' command while performing a transient magnetic electric motor analysis in Maxwell 3D, I am receiving this error. What could be the reason?
    • Timos
      The error often refers to a gap or uncovered areas that are not properly meshed. To resolve the error you should firstly inspect the geometry and the mesh settings. Additionally be sure to assign mesh operations and ensure that the model is properly connected. Please check :
      The Mesh Generation Process (ansys.com)
      Generating the Mesh Without Solving (ansys.com)
