Preprocessing
Preprocessing
Failed to mesh
    • arun_niddish
      How to rectify this error ?
    • Keyur Kanade
      As error says, surfaces are intersecting. Please go to design modeler. Please use share topology. Then please use Tools --> Fault detection to check if geometry has any errors.
      Keyur
    • arun_niddish
      Thanks for the reply , but sorry the method is not working for the problem .
      Thanks.
    • Bhargava Sista
      It is most likely that there are some issues with the geometry. I suggest that you switch to wireframe mode, right click on the error message and go to the offending body to identify the problem. The faulty edges should show up in red so it should be easier to isolate the problem. Then switch back to shaded view and inspect that area carefully. You may need different repair tools depending on the type of artifact in the geometry.
    • peteroznewman
      KUMAR, I moved your question from the end of this solved topic to a new topic so that more people would see it.
Viewing 4 reply threads
