October 28, 2018 at 8:13 pm
KKBH
SubscriberEven after exporting an Induction motor design from RMxpert,
I am getting these errors- "Failed to recover curve outlines" and "Failed to recover circles"
I tweaked stator, rotor bars band everything, still it is going. Just changing the error all the time.
I tried to smooth the curves for stator and rotor using Tool (Band) and normal geometry elements. I also tried Healing. Still not working.
Thanks
- Maxwell, HFSS or Q3D?
- Error
2630
2104
1327
1110
461
