Ansys Products
Ansys Products
Failed to run Explicit Dynamic on ANSYS 18.1
    • rickywugunawan
      Hi everyone, I am trying to run a model using Explicit Dynamics AUTODYN. It was okay before but suddenly I can't run my ANSYS using Explicit Dynamics AUTODYN anymore. I have already reinstalled the program a couple times but it still does not work. This is the preview of the "solution information" and "RSM"
      Explicit Dynamic Solution InformationRSM
      This is the second time I faced this problem. I manage to solve it on other computer by reinstalling and delete all of the ANSYS model inside my computer. I tried to do the same on the other computer but it did not work.
      I saw similar problem on this forum but no one answered yet. can anyone help me?
      Thank you so much
    • Wenlong
      I am looking into this issue and will let you know once I find a solution.
      Wenlong
    • Wenlong
      Sorry for the late response. Just checking when you do the installation, have you installed the MPI?
      Wenlong
    • Wenlong
      If you want to turn off distributed run and run SMP, Aniket pointed out how to turn if off in the old Mechanical interface: https://studentcommunity.ansys.com/thread/mpi-error-while-doing-hyperelastic-simulation/?order=all#comment-21f2cf48-8222-4eed-b1cd-ab9601140727
      Wenlong
    • rickywugunawan
      Hi Wenlong,
      Thank you so much for your time and responses.
      I did not install the MPI though, is it necessary? Because previously I can run my ANSYS just fine before.
      I also follow the Aniket advice to turn off the distributed run. But it still did not solve the problem and I still face the same problem.
       Stuck on
      Is it possible that the problem is on the Explicit Dynamic AUTODYN License?
      Because in my different computer, after the "AUTODYN PRE-SOLVER SETUP COMPLETE." appears, usually it says license acquired or something like that. But this time it can not get the license, thus it won't continue the process.
      Ricky
    • Wenlong
      Hi Ricky,
      Due to my limited knowledge, I don't have a direct answer.
      I found a post on the same issue as yours and it may be helpful to you. https://studentcommunity.ansys.com/thread/explicit-dynamics-on-hpc/.
      Let me ask experts in RSM for help and get back to you.
      Wenlong
    • tsiriaks
      Don't install the extra MPI.
      If this worked before and now showing this issue in RSM report, try this in CMD Prompt
      move "%appdata%ansys" "%appdata%ansys.old"
      If this doesn't help,
      Are you using VPN ?
      Make sure you connect to either LAN or Wi-FI but not both at the same time
      Can you try temporarily disabling all security (Anti-virus, Firewall) on the machine ?
      Thanks,
      Win
    • rickywugunawan
      Hi Win,
      thank you for your response. This is the CMD result, it thinks it doesn't work
      I don't use a VPN. I already try disabling Anti-virus, Firewall, and the Internet. But nothing works.
      I will provide another setting in my model, hopefully, it will be helpful for you.
      Ricky
    • tsiriaks
      Hi Ricky,
      The fact that the first command doesn't work is a red flag. Somehow, you don't have access (mostly 'write' permission) to C:UsersUSERAppDataRoamingAnsys  , please check permissions settings and everything there.
      Thanks,
      Win
    • rickywugunawan
      dear Win,
      Thank you for the advice. Finally, I decided to format my computer and reinstall my Windows and it works. I can use the explicit dynamics normally again now.
      Ricky
    • tsiriaks
      Hi Ricky,
      Great to hear that it's working for you now ! There was some write permission issue, so ANSYS can't write files there.
      Thanks,
      Win
Viewing 10 reply threads
