April 28, 2021 at 6:49 pm
wolfgang.geist
SubscriberHi,
our support person in our company tried to use ANSYS Discovery 2021R1. Before using an older release there was not problem to run the new version. After installation and starting the system our collegue experinced that the system didn´t start an an error message was generated. The installation was done in administrator mode. Download was made again as well as installation
See attached screen shot.
Thanks for help.
Regards
Wolfgang
April 29, 2021 at 6:12 am
Charudatta Bandgar
SubscriberHello Ghost1246
Is this happening while launching discovery or when it is opened and you are trying to perform some operations? Few things you can try are:
1. Clear the contents of the temp folder (type %temp% in windows Taskbar to access temp folder)
2. Close all the open Discovery Applications and go to the following AppData folder (C:Users****AppDataRoamingAnsys) and rename the folder v211 to v211.old)
3. Try updating your graphics driver by visiting the manufacturer's website (eg. NVIDIA, etc)
Please let me know if this does not work.
April 29, 2021 at 9:10 pm
wolfgang.geist
SubscriberHi,
according to our technical person the system is still not working as desired after application of the suggested measures. The system is stopping to work at launching it.
Thanks for further help.
Regards
Wolfgang
May 5, 2021 at 4:41 pm
wolfgang.geist
SubscriberHi,
all recommendations failed. New installation was not sucessful. Version ANSYS SpaceClaim 2020R2 is working on the same system without problem.
3744
2573
1793
1236
594
