March 28, 2022 at 8:57 am
gyan
SubscriberMarch 30, 2022 at 11:52 amNavya C
Not sure what you are simulating exactly. But below are some suggestions based on the error message.
Make sure all the moving objects are enclosed in the band.
Use a segmented band instead of a cylindrical]. Create an additional dummy band object for better meshing in the airgap.
Change the initial meh to a bit finer in the initial mesh settings.
If this didn't work. Please share some screenshots of your model and motion setup.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8740
4658
3151
1678
1452
