LS Dyna
LS Dyna
Failure results of composite materials modeled by Shell163 in Explicit Dynamic (classic-APDL)
    • Sina.Dadashzadeh
      Hi all,
      I'm doing low-velocity impact on composite using explicit dynamic by APDL. To model my composite I used Shell163 and RMODIF command to lay-up it.
      I want to get the failure results like Tsai-wu but I can't. May I ask you to guide me in applying the material model that can be able to see the failure modes?
      Note: I tried FC commands but those ones seem to not working on Explicit Dynamic.
    • Sandeep Medikonda
      Sinad, orthotropic material failure model won't work with LS-DYNA in MAPDL.
      You can try using LS Pre-Post or WB LS-DYNA using Command Snippets.
      Sandeep
    • Sina.Dadashzadeh
      Dear @SandeepMedikonda,
      I appreciate your kind consideration.
      As I developed a code for my model, there is no way to change the software, Can I calculate the Tsai-Wu failure, using the stresses in local coordinates?
      In this case, I should check all the nodes in all sub-steps.
    • Sandeep Medikonda
      Sinad, when you say a code for your model, I believe you are talking about your own material subroutine? If so, yes you can do that. Oftentimes, stresses are rotated into the local co-ordinate systems before they are sent into the material subroutine. So it should be fairly simple both in Autodyn or LS-DYNA (See *MAT_55).
      Also, think about the post softening behavior? I've used a Weibull function in my work.
      https://doi.org/10.1177/0892705717743291
      Sandeep
    • Sina.Dadashzadeh
      No, I directly used orthotropic material, by code I meant the whole model which is modeled parametrically for optimization purpose.
      I agree with you that both LS-Dyna and Autodyn are more convenient to work with, but now, I don't have time to change the software so I'm going to use code to calculate the Tsai-Wu failure. Thank you so much for guiding me with my issue.
Viewing 4 reply threads
