August 30, 2022 at 11:43 am
2212296
SubscriberHi, I'm working on a simulation about metasurface imaging, but I'm having a problem. When calculating far-field imaging, I use the command farfieldexact3d, which will report a syntax error. Could it be a version problem? I am using the 2018 version. I don't know how I can successfully complete this simulation, I hope you can give me some advice, thank you very much
August 30, 2022 at 11:48 am
August 30, 2022 at 9:01 pm
Guilin Sun
Ansys EmployeeIt is due to the version, as this feature to directly calculate farfield from a dataset was intriduced not long time ago, and definitely 2018 version does not have this feature.
Please try to use the newest version.
September 3, 2022 at 6:37 am
2212296
SubscriberThank you very much for your reply!
November 24, 2022 at 1:07 pm
yutong xu
SubscriberHello, does the function of calculating the far field from the dataset 2020 version work
November 24, 2022 at 5:01 pm
Guilin Sun
Ansys EmployeeIt has the features for some new version. I forgot from which version. I strongly suggest you to use the newest version.
November 25, 2022 at 1:28 am
yutong xu
SubscriberOK,thank you for your reply!
- Error on Lumerical device
2656
2116
1339
1118
461
