August 23, 2022 at 8:44 pm
Klotzkin
SubscriberI am trying to do something which is probably simple, but I cannot find the process. I'd like to calculate the far field of some basic laser waveguide modes in the form of line plots (to get perpendicular and parallel FWHM, which are the usual measured numbers). there are scripts like this one ( https://optics.ansys.com/hc/en-us/articles/360034394334-Creating-line-plots-of-far-field-projections) that talk about it, but I cannot find the relevant dataset in MODE (if I use FDE;:data::mode1, it does not work, and there no other monitors explicitely set).
And the second thing is another 'where is the monitor' question. In MODE, how would I calculate the fraction of optical power confined to the quantum wells, to estimate confiment factor?
Thank you very much.
August 24, 2022 at 7:36 pm
Guilin Sun
Ansys EmployeeWhat does your waveguide look like? is it 2D cross section or 1D?
line plot only works for 1D. If it is 2D, you will need to first get the cross section in 1D. Do you have 1D data?
Do you want near field or farfield?
- Error on Lumerical device
2706
2142
1357
1144
462
