May 30, 2022 at 1:38 am
May 30, 2022 at 3:59 pm
Guilin Sun
Ansys Employee不知道啊,没有进一步的信息无法回答。
检查一下监视器里有数据没有?这种分析组的监视器需要同时记录电场和磁场.
我这边测试例子没有问题:
https://support.lumerical.com/hc/en-us/articles/360034395194-Changing-the-far-field-refractive-index-analysis-object
请先测试例子看看能否成功。 -
May 31, 2022 at 5:29 am
June 1, 2022 at 12:08 am
Guilin Sun
Ansys Employee我测试发现单波长是工作的,但是对于多波长,即使网上的例子,也不工作。
数据是有的,很可能是Dataset有问题,我把它改为矢量Dataset,是工作的,当然坐标不对,你知道就可以了:
clear;closeall;
ux=getdata("far_field_change_index","ux");
uy=getdata("far_field_change_index","uy");
f=getdata("far_field_change_index","f");
E2far1=getdata("far_field_change_index","E2far1");
E2far2=getdata("far_field_change_index","E2far2");
ux2=getdata("far_field_change_index","ux2");
uy2=getdata("far_field_change_index","uy2");
E2far2=interp(E2far2,ux2,uy2,f,ux,uy,f);
E2 = matrixdataset("E2");
E2.addparameter("ux",ux);
E2.addparameter("uy",uy);
E2.addparameter("lambda",c/f(1),"f",f(1));
E2.addattribute("E2far1",E2far1(:,:,1));
E2.addattribute("E2far2",E2far2(:,:,1));
visualize(E2);
visualize(E2far1);
visualize(E2far2);
E=getresult("far_field_change_index::field","E");
E1= matrixdataset("E");
E1.addparameter("ux",E.x);
E1.addparameter("uy",E.y);
E1.addparameter("uz",E.z);
E1.addparameter("lambda",c/f,"f",f);
E1.addattribute("Ex1",E.Ex);
visualize(E1);
uz=0;
E2far10=matrix(201,201,1,30);
for(n=1:201){
for(m=1:201){
E2far10(n,m,1,:)=E2far1(n,m,:);
x=ux;
y=uy;
z=uz;
Efar2=rectilineardataset("Efar2",x,y,z);
Efar2.addparameter("lambda",c/f,"f",f);
Efar2.addattribute("E2far",E2far10);
# Efar2.addattribute("E2far2",E2far20);
visualize(Efar2);
需要输出
June 1, 2022 at 1:02 am
Jin_Guangrong1123
Subscriber官网的案例的波长400-700nm,我测试是工作的,当改成单波长分析组就不工作了,这是分析组的设置哪里有问题?
- 询问关于FDTD和matlab软件的互联问题 ——appopen
- Ansys Insight: FDTD 和 varFDTD 常见的发散原因以及处理
- Ansys Insight: FDTD 如何设置圆偏振光
- 如何仿真一维光子晶体能带?
- 老师,您好。FDTD中simulation bandidth和source中wavelength区别在哪里,仿真根据哪个进行?
- Ansys Insight: 透射率反射率大于1,或者透射率反射率之和大于1的原因与解决方案–综合贴
- Ansys Insight: 几个简单实用的脚本Script命令:用于结果分析
- Ansys Insight: FDTD 初学者: 平面波和全场散射场tfsf光源有什么区别
- 左旋圆偏振光透过超表面后,获得的右旋圆偏振光能量比入射的左旋圆偏振光能量还要大?
- Ansys Insight: script中的数据类型和数据格式 Dataset
3648
2512
1741
1226
578
