January 28, 2023 at 6:26 pm
January 30, 2023 at 8:11 pm
Guilin Sun
Ansys EmployeeThis seems from the far field projection for a 2D simulation. You can use script to get it. Please refer
https://optics.ansys.com/hc/en-us/articles/360034410074-farfield2d-Script-command
please try.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5290
3311
2471
