January 19, 2023 at 4:41 pm
Mike Neville
SubscriberHi all, I am trying to use the farfield3dintegrate function as part of a figure of merit for the FDTD optimasation feature, but am getting a message saying this is not a valid function despite it working fine in the script environment. The code i am using is below.
E = farfield.E2;
E=pinch(E);
ux = farfield.ux;
ux=pinch(ux);
uy = farfield.uy;
uy=pinch(uy);
NA=0.3;
acceptangle = asin(NA) *360/(2*pi);
out =1;# farfield3dintegrate(E, ux, uy, acceptangle);
out1 = farfield3dintegrate(E, ux, uy, 90);
powernorm= abs(power);
fom = powernorm * (out/out1);
Farfield is defined as a result in the optimization fom environment. Can anyone suggest why this function may not be working?
January 20, 2023 at 4:54 pm
Guilin Sun
Ansys EmployeeDid you use those script inside Optimization ? it only holds certain script to work there. The best way to do this is in the "model". Then you choose its output as the FOM during the optimization. Please try.
- Error on Lumerical device
2630
2104
1329
1110
461
