November 8, 2018 at 2:16 pm
F. Semih Y
Subscriberon AIM 19.0
I want to merge faces of a rather organic body (maxilla - upper teeth). I was wondering if there is a faster way to detect face sets that can be merged Instead of selecting and trying manually with sur-minimal amount of faces. Just like the small faces tool.
Or are there other tools I could use?
November 9, 2018 at 1:15 am
Sandeep Medikonda
Ansys EmployeeIn SpaceClaim, you can record your commands, save it as a script and run it as needed.
Please see here.
Sandeep
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
