Fast sweep setup, process hf3d: Poor convergence in computing port dispersion error means?
    • ron
      While I'm Simulating the Square ring slot Coupled DRA i'm getting this error Fast sweep setup, process hf3d: Poor convergence in computing port dispersion.
    • VivekKamble
      Hello Could you please let us know any specific reason that you are using Fast Sweep?
      Poor convergence might result due to incorrect exiction/ geometry, I will recommend changing your frequency sweep to interpolating or discrete.
      Please let ins know if you still face the same error after changing the sweep type.
      Regards Vivek
