April 26, 2022 at 1:11 pm
abdoomer199
SubscriberHow can I get wind loads subjected to win turbine from FAST (NREL) to ANSYS ?
April 26, 2022 at 1:59 pmRob
Forum ModeratorWhat do you want to pass to Fluent? Chances are something can be done, but as I don't know what you have & want it's a bit difficult to answer.
April 26, 2022 at 2:07 pmabdoomer199
SubscriberMy study includes getting the dynamic response of wind turbines due to wind load
So I thought the best practice for such problem is to get the wind profile from FAST to ANSYS, However I created a model for it in ANSYS ,but I kinda have doubts about the resultes
April 26, 2022 at 2:48 pmRob
Forum ModeratorYou want to get the speed response? How did you add the profile to Fluent?
April 26, 2022 at 2:52 pmabdoomer199
SubscriberUsing system coupling with transient
April 26, 2022 at 2:54 pmabdoomer199
SubscriberI wanna get the response of wind turbine (tower) due to wind
April 26, 2022 at 3:01 pmRob
Forum ModeratorRight, so the wind speed from FAST is the upstream flow boundary condition in Fluent?
April 26, 2022 at 3:12 pmabdoomer199
SubscriberYes, it is
April 26, 2022 at 3:19 pmabdoomer199
SubscriberOpenFast should replace ANSYS for the response of wind turbine, but itÔÇÖs results is not visualizable
April 26, 2022 at 3:30 pmabdoomer199
SubscriberMy problem will be solved if lÔÇÖve got a manual or a tutorial for wind load simulation on win turbine
April 26, 2022 at 4:18 pmRob
Forum ModeratorLook in Help, all of the public tutorials and examples are in there.
Viewing 10 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
8700
4658
3151
1672
1446
