Ansys Products
Ansys Products
Fatal error Ansys Workbench
    • oanachirila
      I have a problem with opening my model. This error appeared after a blackout. When I tried to open the workbench after the power was restored, this error showed up. The Ansys version I used is 2020 R1. This simulation is very important to me because it run 190 hours and I need the results.
      Can somebody please give me some advice?
      Thank you in advance,
      Oana
      Have you got any saves from during this time?
    • oanachirila
      Yes, I saved the model 5 minutes before the blackout.
    • tsiriaks
      Open CMD Prompt and enter the command
      move "%appdata%ansys" "%appdata%ansys.old"
      then, try your project again.
      If issue persists, this project is corrupted. You will need help from rwoolhou, or other expert in corresponding physics you are doing to help re-build your project and scrap out any info you can use from this corrupted one.
    • oanachirila
      I managed to restore the results and the simulation is now working again.
      Thank you for your help!
    • tsiriaks
      That's great ! You are welcome !
Viewing 5 reply threads
