Ansys Products
Ansys Products
Fatal error showing that “the view ‘graphscene’ has not been registered. how to fix it?
    • rishikesh
      I have installed Ansys 18.2 recently and it worked perfectly, after few days it is showing that "the view Graphscene has not registered".
      Also, I have seen all the posts posted on "Workbench 18.2 fatal error" and implemented all but none of them worked.
      Please, find a solution for this.
    • tsiriaks
      Could you try ANSYS 19.0 or 19.1 to see if this issue is persistent ?
      Thank you,
      Win
    • rishikesh
      Sir, I have installed ANSYS 19.0 and the problem is persistent.
    • rishikesh
      What should I do sir?
      I have been studying for a course from Cornell university. When I first installed 18.2. It was successful and I have done few things on ANSYS. But now it's not working and showing FATAL ERROR, grapheacenw not registered for 18.2and FRAMEWORK ERROR for 19.0.
      My windows laptop is new and has good specifications.
    • rishikesh
      Please give an appropriate solution for FATAL ERROR (graph scene not registered) in ANSYS 18.2 and also FRAMEWORK ERROR in ANSYS 19.0.
      I have tried the suggestions provided on Fatal Error "The GRAPH SCENE has not registered". None of them worked.
    • tsiriaks
      Just for a kick, could you try launching the Workbench with 'run as administrator' to see if that works ? If you don't have admin rights, please ask the person who does to try this. It's a crucial test to narrow down the issue.
      Thank you,
      Win
Viewing 5 reply threads
