Ansys Products
Ansys Products
Fatal Error
    • thuythu
      Help me fix error, please!
      I removed and reinstalled it. But it didn't work
    • tsiriaks
      Hi thuythu ,
      Please provide OS version , ANSYS version , and the exact name of the installation package that you use.
      Also describe how you get to this error , are you trying to launch Workbench ?
      Check if you have the install.err file under (default) C:Program FilesANSYS Inc
      Thanks,
      Win
    • thuythu
      I'm trying to open Workbench ANSYS 16.0 and error appeared.
      I use window 7 professional 64bit
      I don't see install.err file. What should i do?
    • tsiriaks
      Hi thuythu ,
      That's very old version.
      Did it work before ? If so, try reset configuration : Rename folder v160 in this directory
      %AppData%Ansys     (please copy and paste this in the Windows Explorer address bar)
      to anything else (e.g., v160.old)
      Thanks,
      Win
    • thuythu
      Yes,version Ansys workbench 16.0 worked before.
      I renamed folder but it didn't work. I also moved Ansys 16.0 and installed free version student 19.2, but the same error appeared.
      what should i do?
    • tsiriaks
      Make sure you install all pending Windows update.
      Can you try updating your graphics card driver to the latest ?
      Also, what is the graphics card  you have on the machine ?
      Thanks,
      Win
Viewing 5 reply threads
