March 5, 2022 at 12:17 pm
khalid.mahmud.buet
SubscriberWhen I am trying to simulate 3D . It gives me this error " Fatal internal error .Simulation completed with execution error on server: Local Machine. " What should I do;
March 5, 2022 at 5:12 pmpeteroznewman
SubscriberPlease provide a lot more details.
March 5, 2022 at 6:43 pmkhalid.mahmud.buet
SubscriberWhile doing the simulation, it ran well but at the last point it shows "Fatal internal error". For example If it is 36msec simulation,then after 35msec simulation, it shows that error.
March 6, 2022 at 3:01 ampeteroznewman
SubscriberThat is not nearly enough information to help you.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1349
1118
461
