September 18, 2018 at 8:37 am
sohrab
SubscriberHi everyone,
I am trying to model and simulate fatigue crack propagation using XFEM method in APDL.
September 18, 2018 at 8:38 am
sohrab
Following is the meshed model prepared for XFEM analysis
1. 1, ?s it required to define local coordinate system at crack tip in XFEM method?
2. 2, Even in SING method I cannot define my crack tip inside an element, why?
3. In order to constant amplitude loading I follow the following ,
time, 1.0
deltim, 0.02, 0.02,0.02
while
CGROW, FCG, METH, LC ! life-cycle method
CGROW, FCG, SRAT, 0 ! stress-ratio
!loading frequency is 25 Hz
3,Does the abovementioned strategy true?
4. 4,How I can monitor cycle by cycle crack propagation and related crack parameters (a, deltaK and N)?
5. 5, Crack front node number mentioned here does not listed in APDL node list call; is this a virtual node produced fro XFEM?
6. 6,By changing the loading magnitude and frequency I always get the following graphic. There is no change in the amount of crack growth (graphically).
your helps and comments to help me f?nd out my answers are fully appreciated in advance
September 19, 2018 at 3:47 pm
Sandeep Medikonda
Ansys EmployeeHi Sohrab,
It is usually helpful, but it is not required if the crack is aligned with the global cartesian system.
The singularity method allows a crack to terminate within an element, but the original crack tip must be located at node.
DoeDoes the above mentioned strategy true?
It looks OK
You need to use *GET to obtain those values (see example 3.5.5 in the MAPDL Fracture Analysis Guide
Crack front node number mentioned here does not listed in APDL node list call; is this a virtual node produced from XFEM?
yes
The graphic results are scaled to be visible. Use /DSCALE to change the scale factor
Sandeep
Guidelines for Posting on Student Community
September 20, 2018 at 5:23 am
sohrab
Thank you Sandeep for your Answer. youre reply are so helpful.
my concern is that, Does XFEM in APDL automatically take care about tip coordinate to calculate SIFs? if not, then how should crack tip coord'nate be defined to follow crack tip during propagation
in case of crack tip extention Iam not sure how to retrieve crack tip coordinates (as it is a virtual node(in 2D case) ) to measure crack extention at each substep loading.
can you help me in this regard?
but it seems that the crack direction also keeps the same.
and my last question:
how can I stop the loading (simulation) when crack length reaches an specific amount?
Sohrab
September 21, 2018 at 5:45 pm
Sandeep Medikonda
Ansys EmployeeHi Sohrab.
A: You define the crack characteristics, including crack coordinate system, using the CINT command. If you do not explicitly define a crack coordinate system using CINT, the solver assumes that it is global cartesian.
in case of crack tip extention Iam not sure how to retrieve crack tip coordinates (as it is a virtual node(in 2D case) ) to measure crack extention at each substep loading. can you help me in this regard?
A: You cannot *get the “new” crack tip coordinates. You can only obtain the crack extension DLTA. See Example 3.7.5 in the MAPDL Fracture Analysis Guide.
A: The direction should remain constant.
A: There no automated method. You might be able to monitor the crack progression by placing the solve inside a *DO loop with a *IF statement that either processed the next solve or ended the solution based on some variable. You might also be able to use the *DOWHILE command. Either approach would require some sophisticated APDL scripting.
Sandeep
September 26, 2018 at 2:14 pm
sohrab
SubscriberHi Sandeep
first of all thank you for your comprehensive answer.
I progressed a lot in my problem since last post. but now there seems to be a problem with crack definition in ansys.
1. an element with ID 4642 has 2 crack front which is prohibited
2. an element with ID 4635 is not possible to calculate psi and phi values
I double checked every thing but still it does not work for me.If it is possible for you to take look at it would be great. please just let me know if you can check the code to send you the script.
Sohrab
2078
1289
1106
459
