March 13, 2023 at 12:14 pm
zayeem fazili
SubscriberDear members,
I am a PhD student , I am eager to understand SN curve of a material test. If a material is tested the resultant mean SN curve showS 50 % probablity of survival/failure as accepted by many researchers. Or it depends on the tensile stregth of material. If tensile stregth value coresponds to 95 % Probability of survival as per the standards. In that case would the resultand SN curve be also 90 % probability of survival not the 50 % survival.
March 14, 2023 at 11:19 am
Aniket
Ansys EmployeeDuplicate of https://forum.ansys.com/forums/topic/fatigue-sn-curve/, will be answered there.
-Aniket
March 17, 2023 at 8:39 am
David Mercier
Ansys EmployeeHi, some other discussions related to this topic:
- https://forum.ansys.com/forums/topic/sn-curve-values-for-different-material/
- https://forum.ansys.com/forums/topic/how-to-add-sn-curve-for-new-material-in-fatigue-analysis/
You can find some answers to your questions in this training: https://www.ansys.com/training-center/course-catalog/structures/ansys-mechanical-fatigue
Then if you need data, you can find SN curves and documentation for example in Granta databases (EduPack for teaching, Selector and MI for research). See the screenshot below as an example.
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
3812
2607
1853
1244
600
