March 13, 2023 at 12:14 pm
zayeem fazili
SubscriberDear members,
I am a PhD student , I am eager to understand SN curve of a material test. If a material is tested the resultant mean SN curve showS 50 % probablity of survival/failure as accepted by many researchers. Or it depends on the tensile stregth of material. If tensile stregth value coresponds to 95 % Probability of survival as per the standards. In that case would the resultand SN curve be also 90 % probability of survival not the 50 % survival.
March 14, 2023 at 3:14 pm
Daniel Shaw
Ansys EmployeeAnsys is not a testing company. I recommend that you discuss this issue with someone more familiar with fatigue testing. If the SN curve is developed from fatigue test data, typically an mean curve through the data is developed and used, but some industries require using the 1- or even 2-sigma curve from the test data. If the SN curve was developed from test data, it not clear why the UTS would affect it. The SN curve is just a statistical fit to the actual test data. SN curves can be estimated from physical properties (UTS, slope, transition points, etc.). If SN curve is estimated from physical properties, then it would be affected by the UTS value.
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
3694
2564
1765
1236
592
