FC – Failure Criteria
    • Vitaliy_Degtyarev
      Hello All,
      Attached is very simple model of a bar with a non-linear material behavior in tension. I would like the analysis to stop when strains in the bar reach a certain value (0.0175). I used the FC,1,EPEL,YTEN,0.0175 command, but the analysis does not stop at the 0.0175 strain level. Could someone please help me with this? Thanks.
    • peteroznewman
      • /filname,Test
      • /PREP7
      • E=200000
      • mus=0.3
      • Fy=500
      • et,1,link180
      • sectype,1,link
      • secdata,1
      • mp,ex,1,E
      • mp,prxy,1,mus
      • TB,PLASTIC,1,1,6,MISO
      • TBTEMP,0.0
      • TBPT,DEFI,0,500
      • TBPT,DEFI,0.0035,518
      • TBPT,DEFI,0.0070,524
      • TBPT,DEFI,0.0105,529
      • TBPT,DEFI,0.0140,533
      • TBPT,DEFI,0.0175,536
      • FC,1,EPEL,YTEN,0.0175
      • n,1,0.0,0.0,0.0
      • n,2,0.0,10.0, 0.0
      • en, 1, 1, 2
      • /SOL
      • nsel,s,,,1
      • d,1,ux,0
      • d,1,uy,0
      • d,1,uz,0
      • allsel,all
      • F,2,FY,1000
      • ALLSEL,ALL
      • ANTYPE,0
      • TIME,1
      • AUTOTS,1
      • NSUBST,100,10000,100
      • OUTRES,ALL,ALL
      • KBC,0
      • LSWRITE,1
      • LSSOLVE,1,1,1
      • FINISH
    • Rohith Patchigolla
      Hello VitaliyD,
      FC command doesn't work for what you want to do. This is only for post-processing (after completing the solve).
      Please have a look at NLHIST command.
      NLHIST, Key, Name, Item, Comp, NODE, ELEM, SHELL, LAYER, STOP_VALUE, STOP_COND
      You can basically track some variables (nodal/elemental --> max 50 variables) during the solution and you can issue a critical value and a condition which terminates the analysis once the variable becomes greater than or equal to this critical value.
      Hope this helps.
      Best regards,
      Rohith
    • Vitaliy_Degtyarev
      Hello Rohith,
      Thank you for your response. Unfortunately, the STOP_VALUE field is only valid for contact data (Key = PAIR or GCN). I also looked into using TB,FCLI, but it did not work for me either.
      I'm wondering if there is a way in ANSYS to terminate analysis when strain reaches a certain value. Any information on this would be greatly appreciated.
      Thanks,
      Vitaliy
      Hello Vitaliy,
      It is not documented, but it works. Try the below case for example.
      Here, I am loading the block by a strain of 1e-3 and I gave the STOP_VALUE as 5e-4 (half the way through the analysis) and STOP_COND as 1 (stop the analysis once elastic strain X is greater than or equal to 5e-4)
      !beginning of script
      fini
      /clear,nostart
      /prep7
      et,1,186
      mp,ex,1,2e5
      mp,prxy,1,0.3
      tb,biso,1
      tbdata,1,250,2e4
      block,0,1,0,1,0,1
      esize,1
      vmesh,all
      /solu
      nsub,10,10,10
      outres,all,all
      nsel,s,loc,x,0
      d,all,ux
      nsel,s,loc,y,0
      d,all,uy
      nsel,s,loc,z,0
      d,all,uz
      allsel,all
      nsel,s,loc,x,1
      d,all,ux,0.001
      allsel,all
      nlhist,esol,,epel,x,2,1,,,0.0005,1
      solve
      /post26
      esol,2,1,2,epel,x
      prvar,2
      !End of script
      Hope this helps.
      Best regards,
      Rohith
    • Vitaliy_Degtyarev
      Thank you very much Rohith!
      Yes, it works.
      Is there a way to terminate analysis when the maximum strain exceeds a specified limit, but it is not known upfront which element and node will have the maximum strain?
      Thanks again,
      Vitaliy
      Hi VitaliyD,
      If you are not sure of the location upfront where maximum strain can occur, you can try a combination of post-processing in between (to check the maximum strain) and restarts.
      Here are the steps to do.
      - Instead of single load steps, use multiple load steps.
      - Create a do loop, looping over all the load steps.
      - Post-process after each load step for maximum strain
      - Write a condition using *if/*endif commands to terminate the loop if the maximum strain crosses a limit
      - If the maximum strain doesn't cross the limit, go back to /solu, perform a restart from previous LS and continue the simulation.
      Larger the number of load steps, better the resolution at which you can check for the maximum strain condition.
      Hope this helps.
      Best regards,
      Rohith
    • Vitaliy_Degtyarev
      Thank you Rohith. This answers my question.
Viewing 7 reply threads
