June 20, 2022 at 10:06 am
June 20, 2022 at 3:30 pm
Guilin Sun
Ansys Employee主要两个原因:
June 21, 2022 at 2:00 am
656367950
Subscriber请问是哪两个原因呢?
June 21, 2022 at 5:47 pm
Guilin Sun
Ansys Employee抱歉,每次贴图的时候,系统不让发走。这里中回复:
主要是两个仿真的材料与网格不同,请:
1:锁定网格波长范围:在FDTD/Advanced Settings/override simulation bandwidth for mesh generation
2: 锁定材料拟合的波长范围:在材料拟合“Show advanced”
June 23, 2022 at 2:19 am
656367950
Subscriber老师我根据您的方法试过了,但还是不行,请问还有什么其他原因吗?
June 23, 2022 at 6:46 pm
Guilin Sun
Ansys Employee之前我有帖子并有测试结果确认这种方法可行。对于FDTD来说,结构确定后,只要材料核网格一样,应该能都得到一样的结果。参见这个帖子 Ansys Learning Forum
- Error on Lumerical device
3930
2649
1861
1272
610
