November 28, 2022 at 10:00 pm
November 29, 2022 at 6:34 pm
Guilin Sun
Ansys Employeelater, please use a descritive title so it can be helpful for other forum users, and not to be confused with another post.
The "Image" functionality is the original "surface". It is not like the matlab "surface". If you want, please use matlab to plot such surface. MATLAB script integration please check the example file in this link.
- Error on Lumerical device
2630
2106
1335
1110
461
