July 25, 2023 at 8:09 pm
Albi.Pani
SubscriberHi, in the script if I write
S1 = getdata("name", "Ey");
I obtain the "Ey" values recorded by a DFT monitor called "name". Are these values the real one or imaginary part?
How can I select the imaginary part of Ey?
July 25, 2023 at 10:14 pm
Amrita Pati
Ansys EmployeeHi Alberto,
This would give you the complex value of Ey. You can use imag(S1) to access the imaginary part.Regards,
Amrita
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7584
4434
2951
1422
1322
