March 12, 2021 at 7:31 am
llingz
SubscriberHi,nI tried to simulate my final result but the simulation failed. nDetail shows: job aborted:n[ranks] messagen[0-1] terminatedn[2] process exited without calling finalizen[3] terminatedn[4] process exited without calling finalizen[5] terminatedn[6] process exited without calling finalizen[7-8] terminatedn[9] process exited without calling finalizen[10] terminatedn[11] process exited without calling finalizen---- error analysis -----n[2,4,6,9,11] on LINGZHI-LAPTOPnE:\lumerical\lumerical\bin\fdtd-engine-msmpi.exe ended prematurely and may have crashed. exit code 0xc0000005nn
Viewing 0 reply threads
Trending discussions
- Error on Lumerical device
Top Contributors
2564
2080
1299
1106
459
Top Rated Tags
