July 19, 2023 at 9:22 pm
Albi.Pani
SubscriberHi, suppose I have a sovrapposition of two fields with left and right circular polarization respectively. Is there any way to visualize, with the "movie" feature, a component of electric field (for example Ex) belonging only to one of the polarization (for example left circular polarization) ?
July 20, 2023 at 4:30 pm
Guilin Sun
Ansys EmployeeUnfortunately the movie monitor its self cannot display decomposed fields. It displays what is inside the FDTD simulation.
However you can choose individual field component to display (click "field component" tab and choose).
If you want to watch CW movie, then you can display the decomposed field, such as left or right circular polarization using Matlab. Here is an example: https://optics.ansys.com/hc/en-us/articles/360034915793-Making-a-CW-movie-from-a-frequency-monitor
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4500
2957
1449
1322
