February 13, 2023 at 5:44 am
Jaime Rivera
SubscriberHi, I am using FDTD. I have two similar designs except for the sequence of setting up the objects. There is no overlap in the objects so the sequence on when they are built should not matter. I already checked the mesh order and they are the same, so it means that overlapping of two objects doesnt happen.
I use a python code + lumerical script to build these files so I am sure that only the arrangement of the object is changes and nothing more. However, the transmission spectra of these two samples differ (see attached photo). I used mode as the source because Im simulating light propagation in a waveguide. Other than the source, I have no idea where this error is coming from and which one is actually the right simulation.
If you have any idea where is this coming from, please let me know.
February 13, 2023 at 7:59 am
Devendra Badgujar
Forum ModeratorHello Jaime Rivera
This Forum is meant for discussions related to Ansys Discovery products.
Please post your queries related to other Ansys products on ANSYS Student Community or ANSYS Customer Portal based on the type of license that you have.
Regards.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
