Photonics
Photonics
FDTD wavelength and corresponding frequency range ?
    • Mariah Ha
      I would like to calculate the capacitance of a device in CHARGE. I found an example where a capacitance is calculated over a range of frequencies. In my case, I am studiying a single wavelength 0.85 microns. Does that mean that the capacitance will be calculated for a single frequency only?
    • Guilin Sun
      Not sure which example you are referring.
      The capacitance is q/V, or dQ/dv, which is mostly DC value, and it is used in RF analysis, not optical.
    • Mariah Ha
      Thank you for the reply. I mean this parameter in the ssac tab , I am not sure what values should I specify (single or range ....) ? Any details on how to set these ?
    • Guilin Sun
      It should be the CHARGE response frequency which is far lower than optical frequency. You will need to do a transient simulation in order to know the frequency range, I believe.
Viewing 3 reply threads
