October 23, 2023 at 11:19 am
Minhaz Mahmood
SubscriberHello,
I am new to Lumerical so point me in the right direction please. I have the log here:
start running analysis script of ::model::solar_generation ... ...
Error: prompt line 52: in getdata, the d-card named field was not found.
Try the command '?getdata;' to see which d-cards are available.
Error: Result Pabs_thermal_export: variable not found.
Error: Result Pabs_thermal: variable not found.
Error: Result Pabs: variable not found.
Error: Result Pabs_total: variable not found.
Error: Result Jsc: variable not found.
Error: Result G: variable not found.
Error: Result G_export: variable not found.?getdata;
Monitors::0_FTO monitor
Monitors::1_TiO2 monitor
Monitors::2_Meso Monitor
Monitors::3_MAPbI Monitor
Monitors::4_Spiro Monitor
Monitors::5_Ag Monitor
solar_generation
Refractive index
R Monitor
T Monitor
Perovskite monitor
source -
October 23, 2023 at 3:46 pm
Amrita Pati
Ansys EmployeeHi Minhaz,
I believe you are using getdata to obtain the data from "field" in your code. But when you look at the list of available d-cards, there is no object called “field”, which is causing the error. Is “field” a monitor in the simulation?
If you are runing the solar cell simulation from our APP Gallery (Planar Silicon Solar Cell), make sure that you have the monitor called "field" within the "solar_generation" analysis group as shown below (Also make sure that the field monitor has data after the simulation is run, you should see data in the results view when you click on the "field" monitor) as shown below:
Amrita
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
8736
4658
3151
1678
1452
