March 23, 2021 at 11:03 pm
vagelan
SubscriberHi
Iam struggling to define correct boundary conditions and load cases at the GE bracket. I attach two alternatives that I had made. Any advice?
March 24, 2021 at 4:43 pmAniket
Ansys EmployeeAnsys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnMarch 24, 2021 at 9:40 pmMarch 25, 2021 at 6:30 am1shan
Ansys Employee,nThe first 3 cases look good to me. For the forth one I am not sure what you have done. Instead of adding forces you could add a moment and scope it to the bracket circular faces. You may want to make sure the mesh is fine enough by doing a convergence study. Also, you could go a step further and add a contact between bolt and the corresponding surface. This will give you a more accurate representation of the force distribution at the bracket holes.nnRegards,nIshan.nMarch 25, 2021 at 8:29 amMarch 25, 2021 at 3:49 pmViewing 5 reply threads- You must be logged in to reply to this topic.
2600
2086
1317
1108
459
