Kampus Merdeka Belajar
Ask questions related to general and focused sessions
Features of the check case
    • Sholihatun Nisa
      I simulated Flow Through a 90-degree Bend Pipe. At the time of the solution after to generate a monitor for mass balance, why when in the check case there is no recommendation to make at this time? but when in the tutorial on the right there is a recommendation
    • Ilham Rido Arsono
      Hi Nisa, probably because you don't change your setting in solution>methods>turbulent kinetic energy and specific dissipation rate into First Order Upwind or it still default which is using Second Order Upwind, so the result will not be the same as the tutorial. maybe you can check it first. Thank you.
