January 11, 2018 at 9:31 pm
mami826
SubscriberHi All,
my aim is to find the thermal conductivity of litz wire and also convection coefficient of litz wire and air.
So, I am running experimental analysis (10A current into litz wire) and capturing the temperature of litz wire. So, I have temperature profile versus time for litz wire. Would you please help me how I can feed the results (temperature profile) into ansys maxwell (reverse engineering) to define unknown thermal conductivity or in thermal analysis convection coefficient?
Is it possible?
Thanks Regards
Viewing 0 reply threads
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2606
2088
1319
1108
459
Top Rated Tags
