May 18, 2022 at 8:37 pm
shk1048
SubscriberIs it possible to use fem zip. I have actually tried it but didnot work it might be because the lst.k which is created doesnot take this information.
May 24, 2022 at 7:54 amImtiaz Gandikota
Ansys EmployeeFEMZIP is a third party data compression tool. If you're asking if ls-tasc can read and extract results from d3plot files compressed using femzip, the answer is no. LS-TaSC can extract topology results from d3plot and d3part.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3930
2649
1861
1272
610
