June 6, 2023 at 2:12 pm
Neil McFadyen
Subscriberwe are getting a
the library not found error even after I created a link for it
/usr/local/ansys_inc/v222/fensapice/bin/nti_sh: error while loading shared libraries: libqwt-0.4.1.so: cannot open shared object file: No such file or directory
ls -l /usr/local/ansys_inc/v222/fensapice/lib64
lrwxrwxrwx 1 root root 11 May 26 15:58 libqwt-0.4.1.so -> libqut.so.6
lrwxrwxrwx 1 root root 11 May 26 15:29 libqwt.so.4 -> libqwt.so.6
-rwxr-xr-x 1 root root 1688328 May 16 2022 libqwt.so.6
June 6, 2023 at 2:28 pm
Neil McFadyen
SubscriberI fixed the typo for the link,
lrwxrwxrwx 1 root root 11 Jun 6 10:17 libqwt-0.4.1.so -> libqwt.so.6but now getting another library error
/usr/local/ansys_inc/v222/fensapice/bin/nti_sh: error while loading shared libraries: libQt5PrintSupport.so.5: cannot open shared object file: No such file or directory
June 12, 2023 at 5:29 pm
ANSYS_MMadore
Ansys EmployeeCan you please check your installation to our listed prerequisites?
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/installation/unix_platform_libraries.html
June 12, 2023 at 5:54 pm
Neil McFadyen
SubscriberI installed
yum install qt5-qtbase-gui
yum install qt5-qtsvgwhich don't seem to be in the library list but now the library errors are gone now getting a different error - not sure this is the correct way to run fenaspice in batch
/usr/local/ansys_inc/v222/fensapice/bin/nti_sh /home/xxxxx/run_FENSAP_Shot1_FORCLUSTER/solvercmd 2>&1 > fensap.stdout
nti_sh -Undefined variable (Path)(error: 1999)
solver.cmd contents:
#!/bin/sh
#cwd
rm -f .solvercmd.out
export FLUENT_EXE="/usr/local/ansys_inc/v222/fluent/fluent22.2.0/bin/fluent"
export FLUENT_INTEL_MPI_VERSION="2018"
export NTI_DATA="/usr/local/ansys_inc/v222/fensapice/data"
export NTI_PATH="/usr/local/ansys_inc/v222/fensapice/bin"
export Path="/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin;\usr\loca
l\ansys_inc\v222\fluent\fluent22.2.0\multiport\mpi_wrapper\lnamd64\intel\;\usr\local\ansys_inc\v222\
fensapice\bin\;$Path"rm -f .mem_monitor
rm -f converg
rm -f gmres.out
rm -f surface.dat
rm -f hflux.dat
rm -f out
rm -f abortmesg
rm -f probe.out
rm -f fensapstop.txt
rm -f solnecho STEP:FENSAP >> .solvercmd.out
which "/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec.hydra"
if [ $? -ne 0 ]; then
echo ERROR: "/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec
.hydra" not available >> .solvercmd.out
sleep 1
exit 1
fi
"/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec.hydra" -local
only -np 1 "/usr/local/ansys_inc/v222/fensapice/bin_mpi/fensapMPI.exe" >> .solvercmd.out 2>&1
"\usr\local\ansys_inc\v222\fensapice\bin\testWaitFileNormally" fensapstop.txt .solvercmd.out NORMALL
Y,normally,request
if [ $? != 0 ]; then
echo ERROR: execution error >> .solvercmd.out
sleep 1
exit 1
fi -
June 12, 2023 at 6:21 pm
Neil McFadyen
Subscriberi fix the PATH variable (caps needed) but still getting an error related to mpi options [mpiexec@c201m128.local] match_arg (../../utils/args/args.c:254): unrecognized argument localonly [mpiexec@c201m128.local] HYDU_parse_array (../../utils/args/args.c:269): argument matching returned error [mpiexec@c201m128.local] parse_args (../../ui/mpich/utils.c:4770): error parsing input array [mpiexec@c201m128.local] HYD_uii_mpx_get_parameters (../../ui/mpich/utils.c:5106): unable to parse u ser arguments ERROR: cannot stat fensapstop.txt ERROR: (abnormal program end of NFS/filesytem problem) ERROR: execution error -
June 12, 2023 at 6:30 pm
Neil McFadyen
Subscribermore .solvercmd.out
STEP:FENSAP
/usr/local/ansys_inc/v222/fensapice/bin/fensapMPI: error while loading shared libraries: libmpi_wrap
per.so: cannot open shared object file: No such file or directory
ERROR: execution error#!/bin/sh
#cwd
export PATH="/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin;\usr\local\ansys_inc\v222\fluent\fl
uent22.2.0\multiport\mpi_wrapper\lnamd64\intel\;\usr\local\ansys_inc\v222\fensapice\bin\;$PATH"rm -f .mem_monitor
rm -f converg
rm -f gmres.out
rm -f surface.dat
rm -f hflux.dat
rm -f out
rm -f abortmesg
rm -f probe.out
echo ERROR: "/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec.hydra" not available >> .
solvercmd.out
sleep 1
exit 1
fi
"/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec.hydra" -np 1 "/usr/local/ansys_inc/v222
/fensapice/bin/fensapMPI" >> .solvercmd.out 2>&1
"/usr/local/ansys_inc/v222/fensapice/bin/testWaitFileNormally" fensapstop.txt .solvercmd.out NORMALLY,normally,request
sleep 1
exit 1
fi
7592
4440
2953
1427
1322
