FEUL SPRAY simulation
    • mlutfiaziz32
      guys, is my step true? i hope you can corrected my step.
      this is the conditional experiment. so my step :
      why if i set operational condition pressure and desity this notif show and the result error??
    • RK
      What is the end goal of your simulation? and you sure of acceleration due to gravity is in positive X direction?
      Rahul
    • mlutfiaziz32
      my goal :
      1. leght tip penetration
      2. angel spray
      3. suter mean diamter
      yes, because in my feul spray i assume to x direction
    • DrAmine
      The input for the particle diameter is wrong. If you don't know further details but injector type use one of primary atomizer models.
    • mlutfiaziz32
      i use injector by 0.17 mm hole diameter  so i input my particle diameter 0.00017 m
    • mlutfiaziz32
      what do you think in my case, what is atomizer model should I use? plain-orifice atomizer OR pressure-swirl atomizer OR flat-fan atomizer OR air-blast / air-assisted atomizer OR effervescent / flashing atomizer
    • DrAmine
      In the description it does only refer to hole diameter. Kind of atomizer should be known otherwise you need to make assumptions or resolve the primary break-up region
Viewing 6 reply threads
