Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
FFT2D of Radial Electromagnetic Force Density of Three-phase Induction Motor
    • Peter8415
      Hello everyone! How can I get a  FFT2D result of Radial Electromagnetic Force Density of Three-phase Induction Motor?I'll thanks a lot If one can give me a  matlab script.
    • Reshmi Raghavan
      Hello Peter,
      FFT can be extracted directly within Maxwell. Please look for the topic of " Perform FFT on Report" in Maxwell help. Once you have the result extracted the Perform FFT on report option from Results can be used to extract the data.
    • Rosalie Nelson
      Be aware that running this script will result in an error if you have not already imported the data for the radial electromagnetic force density into a variable named radial_em_force_density. It is possible that you will need to make adjustments to the script in order to accommodate the data if it is stored in a different file or format.
      papa's freezeria
