FGM combustion model with premixed methane-air mixture
    • saqibakhtar
      Hello Everyone,nI hope this message finds you well. Actually, I'm trying to use the FGM combustion model for the premixed methane-air combustor. Here, I'm having one problem like in the pdf table temperature seems constant and its value is same as the initial temperature. I just want to confirm whether Is there any tutorial explaining FGM with a premixed combustion model? nYour help will be highly appreciated.nThank Youn
    • RK
      Hello, nProbably, the flow is not converged. If this is the case. let the simulation run further. If you are having difficulty in convergence, lower the URF values. Let us know if this works. n
