March 19, 2021 at 4:44 am
Abi
SubscriberHow to calculate System Fidelity Factor (SFF) in HFSS?n -
March 23, 2021 at 11:52 am
VivekKamble
Ansys EmployeeHelloArray,If you have a formula for SFF, you can implement it using Field Calculator.nKindly go through the Using the Fields Calculator section of the HFSS Help document for more detailed information for your need.nnRegards,nVivekn
- Maxwell, HFSS or Q3D?
- Error
2726
2146
1357
1150
462
