August 18, 2018 at 11:38 am
KumarVaibhav
Subscriberi have observed that using ansys is occupying my C drive like anything so i changed the permanant and temporary file locations to D and E see the screenshot but my software is malfunctioning i think?Pls explain if i willl be able to open my old files with the default settings as before
August 18, 2018 at 1:42 pm
Sandeep Medikonda
Ansys EmployeeHow is it malfunctioning? Please explain.
How much disk space are you talking about? Can you provide some numbers of the drive and your computer specifications?
Lastly, are you working off a saved file or an unsaved file?
August 18, 2018 at 2:22 pm
KumarVaibhav
Subscriberi have a 250 Gb SSD drive in c and 1TB in D and E.it Is i7 processor with 32gb ram with windows 8.1 x64
yes i am working with unsaved file often
August 18, 2018 at 2:41 pm
Sandeep Medikonda
Ansys EmployeeOk So, save the workbench file on the D drive, i.e., the wbpj file, close an open or restart the computer even. I am guessing that the %appdata% environment variable is not updated.
As a check see where
%appdata%ansys
points to when you open that location in a file manager or a command prompt?
Sandeep
August 20, 2018 at 7:36 am
KumarVaibhav
Subscribersandeep can u tell me why i am not getting the green ticks after solving the model i instead get these green download sort of symbols due to which i am not able to view the solution parameter outputs.How should i restore my settings default ones back?pls help see the screenshot
August 20, 2018 at 11:50 am
Sandeep Medikonda
Ansys EmployeeIt means a successful background solution that is ready for download. Please see this section of the manual.
Sandeep
- Workbench error
- Workbench not opening
- License Error
2630
2110
1335
1110
461
