September 2, 2019 at 2:03 pm
rg
SubscriberHi why when I go to turn off the component I have that kind of surface left? Ā If I open the file and save it and try to open it it generates this error, the file is damaged?
š This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
September 3, 2019 at 6:46 am
Gaurav Sharma
SubscriberHiĀ Roberto
This seems to be an issue with just the preview and not the file. What is you open the file, does it open in SpaceClaim.
The issue with preview can most be fixed by:
- Update Graphics card.
- Run the installer again and select "Repair", need not do a complete reinstall.
What surface you are trying to highlight here. Is it the component named "Spiegato". If yes, that can be deleted manually by right clicking on it and select delete.
Please let me know if I have made a mistake in understanding your query or if you need any further assistance.
Thanks & Regards,
Gaurav
September 3, 2019 at 7:59 am
September 4, 2019 at 11:04 am
rg
SubscriberHiĀ
Ā
Were you able to reproduce the problem?
Ā
Regards
September 5, 2019 at 10:44 am
September 5, 2019 at 11:20 am
rg
SubscriberGaurav_ANSYSĀ Hi
Try turning it off and turning it on several times after a while the error appears or you can rotate and press the home buttonĀ
Sometimes the error does not, can it be that it is the fault of the graphics card plus the file is a bit damaged?
regardsĀ
September 9, 2019 at 10:16 am
Gaurav Sharma
SubscriberRobertoĀ
Not sure, though performing a number of operations too quickly can also lead to some issues and its better to avoid.
Updating graphics card from manufacturer's website is also worth a try.
Gaurav
September 9, 2019 at 10:52 am
rg
SubscriberGaurav_ANSYSĀ Hi Gaurav , thank you very much
Computational Fluid Dynamics (CFD) helps engineers design products in which the flow of fluid components is a significant challenge. These different use cases often require large complex models to solve on a traditional workstation. Click here to join this event to learn how to leverage Ansys Fluids on the cloud, thanks to Ansys Gateway powered by AWS.Ā
Earth Rescue ā An Ansys Online Series
3850
2629
1853
1246
600
Ā© 2023 Copyright ANSYS, Inc. All rights reserved.
