Photonics
Photonics
File not found error (parameter sweep)
    • rvpandohie
      I've been trying to run a parameter sweep on Lumerical FDTD for a while now (on my lab's desktop) and keep running into the "File not found" error (picture attached)
    • Kyle
      This error might be due to some other issue with special characters in the file name, for example the apostrophe. Can you try running it with a file path that has no special characters in it?
    • rvpandohie
      thank you so much, that worked!!
