October 9, 2020 at 9:02 am
cbur
SubscriberNous avons rencontré un problème sur SpaceClaim, lors de l'enregistrement d'un fichier SpaceClaim, il est fermé. Le fichier en question a disparu dans le répertoire et à la place un fichier avec une extension ".3bc" est apparu et il était impossible d'ouvrir ce fichier avec SpaceClaim (nom de fichier d'origine: A20068A-EA136-PL01-REV00.scdoc / nom après problème: lqaozppk .3bc). Nous avons réussi à ouvrir à nouveau le fichier en changeant l'extension de fichier en ".scdoc". Avez-vous déjà rencontré ce problème? Avez-vous une explication à ce problème?
October 9, 2020 at 9:05 am
cbur
Subscriberwe encountered a problem on SpaceClaim, during the saving of a SpaceClaim file it is closed.
The file in question disappeared in the directory and instead a file with a ".3bc" extension appeared and it was impossible to open this file with SpaceClaim (original file name: A20068A-EA136-PL01-REV00.scdoc / name after problem: lqaozppk.3bc) .
We managed to open the file again by changing the file extension to ".scdoc".Have you encountered this problem before?
Do you have an explanation for this problem?
October 9, 2020 at 10:39 am
Charudatta Bandgar
SubscriberHello, charlie ,
I am looking into this, will check if anyone else got into a similar issue and also will get in touch with the experts to understand regarding it.
Regards.
October 9, 2020 at 2:14 pm
Charudatta Bandgar
Were you saving it on the network or locally on your computer?
October 14, 2020 at 7:41 am
cbur
SubscriberHello,
Sorry for the response time,
The file has been saved on a server-
November 2, 2020 at 10:46 am
Charudatta Bandgar
SubscriberHello charlie
When you are working with a server, while saving the files, SC creates a .3bc file during the transition. And the corruption might have transitioned to this midway file and stopped. (This does not happen when you are working locally. I hope that answers your query.
Regards.
3930
2649
1865
1272
610
