3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
File saving
    • Roberto
      When I save new drawings on the server everything is fine while when I take one I modify it and try to save it from saving error impossible to save the document what can it be?
      Regards
    • Devendra Badgujar
      Forum Moderator
      Hi Roberto
      Is the issue happening with specific file or with other files as well. Please can you share the file I will check it on my end.
      Regards
    • Roberto
      Hello Devendra Badgujar
      The problem occurs with all scdoc files, step.
      Could it be a server problem? Who does not let save the file?
      Regards
    • Devendra Badgujar
      Forum Moderator
      Hello Roberto
      Could you please confirm that you have read-write permissions to the location where you are trying to save the file?
      Could you try changing the file path for saving?
      Please go through this post file saving problem - Questions - Ansys Discovery Forum and see if it helps.
      If the error persists, please share the SpaceClaim log file created in the below path from the session in which you tried to save.
      C:\Users\username\AppData\Roaming\SpaceClaim
      Regards.
Viewing 3 reply threads
