Ansys Free Student Software
file transfer
    • ksharp1990
      can man use ansys electronic desktop 2019 open the aedt. from ansys electronic desktop 2020?
      Most applications will open older format files, reading newer format into an older version is less likely to work. Try it as sometime you'll be lucky. Note, applications that don't need to run under Workbench or AEDT are more likely to read newer files as the version checks may not be present: you then need to see what did read in as changes in the solver can cause some settings to become corrupt.
