Discovery Import
Discovery Import
File with single line font not exporting
    • devy
      currently it's not possible to export a file to DXF if there's a single line font that is set to engraving. I guess in release 18.1 or so it worked but now not anymore.
      Single line fonts are used a lot within the sheet metal industrie. Especially for engraving partnumbers. If you have a double line it will take double of the time to engrave.
      Attached a font that can be used. (open the ZIP file and drag and drop the TTF files into :Cwindowsfonts.
      It might can be of that in the latest Disovery versions you can only export with Teigha instead of RealDWG ?
      Looking forward to hear from you.
    • Brian Bueno
      Devy van Dinteren
      The attachment seems to be missing.  I have reproduced this on my own machine.  As for RealDWG, I don't believe we support this any more.
      I will have to inquire with the development team.
    • devy
      hi Brian ,
      looking forward to the response of R&D. Also with eyes on Trumpf OEM, they will get this issue as well.
      Thanks for following up.
      • Brian Bueno
        Devy van Dinteren
        It seems if you unfold a sheet metal part, light weight notes get imprinted and then can be exported to dxf (not from the 3D part).
      • devy
        Brian Bueno
        Yes, but not when it's a single line font. Please try with those font: http://www.mrrace.com/CamBam_Fonts/
        Please let me know. At our computers it's not working anymore since I guess the last 2 versions of SC.
      • Brian Bueno
        Devy van Dinteren
        Sorry this question went from one developer to another and I think the single line font requirement was missed.  I've just communicated that to them and will update you.
      • sander
        Brian Bueno Hi Brian, news on this bug?
      • Brian Bueno
        SAESC
        I've just received word from the development team that a fix has been added to 2019 R3
      • devy
        Brian Bueno great to hear. What will be the release date?
      • Brian Bueno
        Devy van Dinteren
        We don't have an exact date yet, but the estimate is sometime around September
    • devy
      Hi Brian Bueno ,
      we've test this in 19 R3 but it is not solved yet. Can you ask development?
      • devy
        Brian Bueno ??
      • Brian Bueno
        Devy van Dinteren
        We examined this and it appeared to not be resolved in R3.  I'm confirming with the development team.
      • Brian Bueno
        Devy van Dinteren
        Development has confirmed that it is resolved in SC 2020 R1.
Viewing 3 reply threads
